Hello. Is there a way to set deblocking strength and threshold in Avidemux when encoding video to the x264 format? I don't see any related field inside the tabs of the encoder configuration window.
And why are all of the "Quantiser" tab fields disabled? Avidemux doesn't let me change any of the "Quantiser control" and "Quantiser Curve Compression" values, though I managed to change the "Adaptive Quantisation Strength" after having activated the "Macroblock-tree Rate Control" in the "General" tab.
Thank you very much.![]()
Falco2000, video newbie.
Let's everyone help each other. -
[QUOTE=brusno;2228316] Thank you very much Brusno, I forgot that some weeks ago I saw the name "loop filter" associated to the x264 deblocking function.
Thank you. Did you already know that thread or did you find it on the fly using Google? If you used Google, what text string did you entered in the search field?Falco2000, video newbie.
I looked in the forum for avidemux:
http://www.avidemux.org/smf/
http://www.avidemux.org/smf/index.php/board,6.0.html
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 15:13 -
Help with Best x264 Settings and Virtualdub Avidemux
By ZZen in forum EditingReplies: 13Last Post: 9th Jun 2009, 09:48 -
x264 Producing Strange Artifacts in Fields of Light Color
By WhoThatBe in forum DVD RippingReplies: 5Last Post: 13th Mar 2009, 16:53 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59 -
Please help! Corrupted x264 video preview/output in AviDemux
By bigshotceo in forum EditingReplies: 1Last Post: 31st Dec 2008, 09:48
